I would like to create a layout document from the current sketchup model, and then add some dimensions in that document between certain entities in the sketchup model. I can do that easily enough from the UI, but I can’t seem to get a grip on the entities in the imported model so that I can use Layout::LinearDimension.new(start_point, end_point, height)
I believe you must use connection points into the model, see:
Any idea why the Layout::ConnectionPoint
constructor expects a string for the pid? When I get entitiy.persistent_id
, it’s an int. If I use to_s, I get Error: #<ArgumentError: pid must be valid>
This retrieves 154 hits for API doc booboos:
Make it 155 and please open an issue for the incorrect argument type.
Is this really a doc error? The method does require a string. It’s just that the pid I get from the entity in my model does not seem to be valid.
Well, it sounds like some kind of issue, bug or whatever.
