I am struggling a bit with placing some construction points based on some UTM32 coordinates I pulled from a public provider.
The points are all placed correctly relative to each other, but when overlayed over a geolocation snapshot the figure looks mirrored, rotated and squashed.
The model is geolocated:
I tried to run the following code in a model geolocated near the point:
point = [6116763.558, 519305.906]
utm_zone_number = 32
utm_zone_letter = "U"
model = Sketchup.active_model
pointutm = Geom::UTM.new utm_zone_number, utm_zone_letter, point[1], point[0]
point3Dutm = model::utm_to_point(pointutm)
utm_from_point = model::point_to_utm(point3Dutm)
For some reason the coordinates from the source are y, x it looks like.
The UTM object:
pointutm
UTM(32 U 519305.90600 6116763.55800)
but the conversion to a point3D seems to be wrong, because if I convert the point3D back into UTM the coordinates are not the same:
utm_from_point
UTM(32 U 519495.01108 6116192.84162)
What gives? They are off, but not by that much.
model.get_datum gives me “WGS 84” if that has any significance.
There are some quirks and errors in the API, ie, here’s one reported just the other day:
I’ve got a georeferenced model and I want to import some data into it. The data comes from OpenStreetMap and contains lat and lon coordinates, so I used Sketchup’s internal function model.latlong_to_point . But the resulting data were created 5 228 000 km far from origin, although they are in the same area as the model. Furthermore they were stretched in the north-south direction and flipped as shown in this image:
[image]
(Blue edges = imported data, other colors = original model)
I found…
So it’s ok to assume that utm_to_point is also expecting the coordinates reversed. But utm_to_point takes a UTM object, and not an array.
Anyway, I converted UTM to latlong and then from latlong to point:
pointll = pointutm.to_latlong
point3D = model::latlong_to_point([pointll.longitude, pointll.latitude])
and it worked! Also on the complete set, and it matched perfectly.
Thank you for the help, and it sure looks like there is room for improvement in these methods.
HA! What a brain fart. I can of course just make the UTM from the y, x order from the source and everything works without converting to latlong.
No, I didn’t mean this. Just that there have long been errors in the API documentation. (So do not be surprised if you find some errors.)
You said, …
You did not tell what the source was (or give us a link.)
In my quick test, I did:
pointutm = Geom::UTM.new utm_zone_number, utm_zone_letter, point.x, point.y
And then tested that pointutm.x and pointutm.y returned that same values that were passed to the object constructor.
They did.
Again, if the “source” is non-standard, how could the SketchUp API know this ?
Correct.
