I created simple script to show the length, area and volume for an object as video below. Pls review and give me your thoughts. Thanks.
So what happens when the object you are hovering over is scaled ?
Thank you so much for your comment. Actually I am really fresh in coding so I am not sure I understand what you said. But I will check with an object to be scaled and revert the result to you.
Anyway, thank you so much for your comment. It seems open something new for me.
Thank you so much.
If a component or group instance is scaled, the instance’s transformation must be passed into the Face#area() method.
See:
[Example] A simple FaceSniffer tool extension
… and this discussion …
Find area of scaled faces? - Developers / Ruby API - SketchUp Community
Wow wow. Thank you so much. I understood what you said right now. It seems I a missing something already. Let I check the code again and hope it can be somehow comply with your requirements. You are really open the new world for me.
Thank you so much with really appreciate.
