Getting Units Settings Via the API
The API OptionsProvider for "UnitsOptions" has interdependent options that do not always return values that we would expect.
“In a nutshell”, when the 'LengthFormat' option is set to any other format option than Length::Decimal, the LengthUnit, AreaUnit and VolumeUnit options do not return actual values.
This means you must use custom methods in your extension(s) to get the correct value.
Length:
def get_unit_length
opts = Sketchup.active_model.options['UnitsOptions']
format = opts['LengthFormat']
case format
when Length::Decimal
opts['LengthUnit']
when Length::Engineering
Length::Feet
when Length::Architectural, Length::Fractional
Length::Inches
else
-1 # unknown format
end
end
Area:
def get_unit_area
case format
opts['AreaUnit']
when Length::Architectural, Length::Engineering
Length::SquareFeet
when Length::Fractional
Length::SquareInches
else
-1 # unknown format
end
end
Volume:
def get_unit_volume
case format
opts['VolumeUnit']
Length::CubicFeet
Length::CubicInches
else
-1 # unknown format
end
end
