Textures turning into solid colors
Hello! Is someone able to assist on why a texture turns to a solid color? It shows when I first open the file, then turns solid as I continue working. This is happened in the past to other files as well. Thank you in advance! Jessica
You need to check the current style. From the Style Toolbar, it should be “Display shaded using Textures”
Thank you! I had that turned on when I closed the file, and didn’t open back as that. Sorry that was such a simple fix.
