I was testing the Medeek Project plugin yesterday a little further in SU 2024 and I noticed that my Grid Tool does not display the same as it did in previous versions of SketchUp.
I look at the stipple pattern (valid strings) this morning and noticed that they show:
Has this recently changed? I’m not seeing any documentation showing this change or that the three dot pattern is supported. I’m not sure what is going on here.
P.S.
Maybe I’ve been using the wrong pattern all along?
So I updated my code to the proper “Dotted Line” with a single dot “.”, and there was zero difference.
I then changed to the legacy graphics engine in SketchUp and bingo the construction lines appeared as they should, however I will say they don’t quite render as good as they did in 2023 or other previous versions of SketchUp. There is something a little off when a dotted construction line is used, the dots kind of bunch up and do weird things (this could be my graphic card?).
It would appear that when the new graphics engine is being used the stipple pattern of the construction lines is ignored.
Can anyone else confirm this?
P.S.
Can this be added to the todo list for the next patch of SketchUp 2024?
I still have not seen a resolution with this bug. Can anyone from the SketchUp team give me any further information or updates? The issue started with SU 2024 and as far as I can tell is still an issue with SU 2025.
My grid tool in the Medeek Project plugin uses the various stipple patterns to help differentiate between major and minor grid lines.
This was never an issue in prior versions of SketchUp (2017 - 2023) so something in these last two versions has broken the proper rendering of the various stipple patterns. I am hoping for a resolution on this with the next release of SketchUp.
