Dear Friends,
This is an example that written by our friend Jason E. Holt. This plugins can make a hole in a box but if box is a group or component, this plugin has malfunctioning. Can any one solve this problem?
Hacked together from the linetool example by Jason E. Holt
Copyright 2005-2008, Google, Inc.
This software is provided as an example of using the Ruby interface
to SketchUp.
Permission to use, copy, modify, and distribute this software for
any purpose and without fee is hereby granted, provided that the above
copyright notice appear in all copies.
THIS SOFTWARE IS PROVIDED āAS ISā AND WITHOUT ANY EXPRESS OR
IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
require āsketchup.rbā
class Drill
@@drill_diameter = 1
This is the standard Ruby initialize method that is called when you create
a new object.
def initialize
end
def draw(view)
Sketchup::set_status_text āDIAMETERā, SB_VCB_LABEL
Sketchup::set_status_text @@drill_diameter.to_s, SB_VCB_VALUE
end
The activate method is called by SketchUp when the tool is first selected.
it is a good place to put most of your initialization
def activate
end
The onLButtonDOwn method is called when the user presses the left mouse button.
def onLButtonDown(flags, x, y, view)
center_ip = Sketchup::InputPoint.new
center_ip.pick view, x, y
face = center_ip.face
center = center_ip.position
normal = face.normal
if ( face )
circle = view.model.entities.add_circle center, normal, @@drill_diameter / 2.0
other_entities = face.all_connected
reversed_normal = normal.reverse
circleface = nil
# This seems lame. add_circle seems to add it as a face, but then I have
# to go looking for that face.
for other in other_entities
if other.typename == "Face" and other.classify_point(center) == 1
#UI.messagebox("found myself :/")
circleface = other
end
end
# Find a face opposite the one they clicked in
#UI.messagebox("type is " + other.typename)
if reversed_normal.samedirection? other.normal
#UI.messagebox "found it!"
point_on_other_face = center.project_to_plane other.plane
if other.classify_point(point_on_other_face) == 1
#UI.messagebox "yes, point projects onto other face."
pushpull_distance = point_on_other_face.vector_to(center).length
circleface.pushpull(-pushpull_distance)
else
#UI.messagebox "nope, doesn't project"
end
else
#UI.messagebox "nope"
end
end
end
view.model.commit_operation
else
UI.messagebox "Drilling only works on faces"
end
end
def onUserText(text, view)
# The user may type in something that we can't parse as a length
# so we set up some exception handling to trap that
begin
value = text.to_l
rescue
# Error parsing the text
UI.beep
puts "Cannot convert #{text} to a Diameter"
value = nil
Sketchup::set_status_text "", SB_VCB_VALUE
end
return if !value
@@drill_diameter = value
end
end # class Drill
This functions is just a shortcut for selecting the new tool
def drill
Sketchup.active_model.select_tool Drill.new
end
UI.menu(āPlugInsā).add_item(āDrillā) {
drill
