SKP to IGES or STEP (for metal fabrication)
Hi Jim,
When you say connected the corners do you mean the bends? If so I had to do that also.
And deleted the inside stuff means you had to make the object hollow (as I did)? Why did you make the tabs smaller?
I agree the price is a bit steep. I will want to do multiple pieces but each is a bit different.
One offs are always more? It seems we have done the hard work designing the piece and cutting the flat projection should then be easy as it will programmed for the machine? I don’t know if the bends are done manually?
Jerry
Jerry
