Could any one tell me why?
view.write_image keys
is making before
Sketchup.send_action ('viewRight:')
Sketchup.send_action ('viewIso:')
Sketchup.send_action ('viewZoomExtents:')
in following code:
Sketchup.send_action (‘viewRight:’)
Sketchup.send_action (‘viewIso:’)
Sketchup.send_action (‘viewZoomExtents:’)
keys = {
:filename => “c:/tmp/write_image.png”,
:width => 1000,
:height => 500,
:antialias => true,
:compression => 0.9,
:transparent => false
view = Sketchup.active_model.active_view
view.refresh
Please
Set your Scene transition times to 0.
Jim,
It did not help. Still the same.;-(
mamjankowski:
Maybe a short timer?
UI.start_timer(0.1, false) { view.write_image keys }
it works fine for me, but I suggest you remove the whitespace before the brackets…
Sketchup.send_action('viewRight:')
and parenthesise
view.write_image( keys )
whitespace inside () is optional…
john
I have just tried this solution and it worked. But I think its a little bit strange to use start_timer in this case.
But, if there is no another way…
Anyway, thank you Jim.
In may case does not work, maybe that’s because I don’t have pages(scenes)…
I meant your original code works for me…
regardless of the transition time…
what SU version are you using [maybe fill in your profile, as well]
john
15.2.685 64-bit
it is filled
Now is filled, of course.
5 min ago wasn’t.
p Sketchup.send_action('viewRight:')
p Sketchup.send_action('viewIso:')
p Sketchup.send_action('viewZoomExtents:')
keys = {
:filename => "c:/tmp/write_image.png",
:width => 1000,
:height => 500,
:antialias => true,
p view.refresh
view.write_image(keys)
this should return
true
true
true
#<Sketchup::View:0x007ff6a79984c8>
true
I’m on a mac and v16, but they are normally fussier…
john
