SketchUp SDK C SUCurve polygon or circle issue
We encounter two issues in the import, to our application, of SketchUp files via SketchUp C API. The issues are related to SUArcCurve, SUCurve, and SUDrawingElementRef. Could you please advise?
To illustrate the issues, in SketuchUp application, created a polygon with 6 segments and a circle only without faces. Polygon created on ‘P’ layer and Circle on ‘C’ layer. The SketchUp file named sample.skp.
when I import this file in our application through SketchUp C API found the two issues:
Issue (1) as shown in the code below, for SUArcCurve and SUCurve SUDrawingElementFromEntity() always returns nullptr. Please see the comment inside the function
// Import curves
void ImportSketchUpImpl::ImportCurves(const SUEntitiesRef &entities, Dbms::LayerPtr parentLayer, const ColourValid &parentColour)
    	size_t curveCount = 0;
    	SUEntitiesGetNumCurves(entities, &curveCount);
    	if (curveCount > 0)
 		std::vector<SUCurveRef> curves(curveCount);
    		SUEntitiesGetCurves(entities, curveCount, &curves[0], &curveCount);
    		ColourValid colourValid;
    		for (size_t i = 0; i < curveCount; ++i)
    			if (IsCancelled())
    				return;
    			SUDrawingElementRef drawingElementRef = SUDrawingElementFromEntity(SUCurveToEntity(curves[i]));
    			if (SUIsValid(drawingElementRef))
    				// Never reached here. SUDrawingElementFromEntity always returns nullptr even though there is always a valid entity as curve is an entity (upcast). Need SUDrawingElementRef to get the layer colour, ...etc
    				// colour, layer..
Issue (2) I didn’t find away to tell whether the curve is a polygon or circle. Here is the code snippet that shows the import. Please see the comments.
 // Get curve
 Dbms::LinePtr ImportSketchUpImpl::GetCurve(const SUCurveRef &curve)
	if (SUIsInvalid(curve))
		Assert(false);
		return nullptr;
	size_t curveEdges = 0;
	SUResult result = SUCurveGetNumEdges(curve, &curveEdges);
	if (result != SUResult::SU_ERROR_NONE)
		Assert(false);
		return nullptr;
	Dbms::LinePtr curveLine;
	if (curveEdges > 0)
		curveLine = Dbms::CreateLine();
 		SUCurveType curveType = SUCurveType::SUCurveType_Simple;
 		SUCurveGetType(curve, &curveType);
 		SUArcCurveRef arcCurve = SUArcCurveFromCurve(curve);
 		if (SUIsValid(arcCurve) && curveType == SUCurveType::SUCurveType_Arc)
 			// Reach here for both the polygon and circle. i.e the circle and polygon has SUCurveType::SUCurveType_Arc even the downcast is successful to SUArcCurveRef
 			// So how to tell whether this a polygon or circle.  Here if is a circle and we need to deal with it different than a polygon.
 		else
 			// Line segments....
 	return curveLine;
Thanks,Issue2PolygonOrCircle.skp (103.3 KB)
ArcCurve and Curves aren’t derived from DrawingElement. They are derived directly from Entity (similar to Vertex). Curves in SketchUp are meta-entities composed of a set of edges - a means to store their curve relationship. Edges are DrawingElements - as they are seen and manipulated directly in the viewport.
Can you provide an example model to accompany this code example?
Thanks. I will use one of the edges to get a drawing element as they should be the same for all edges within the same curve or arccurve. is that right?
Sure. Attached “Issue2PolygonOrCircle.skp”
I see now. There’s a short coming in the C API. A hexagonal curve is represented in SketchUp as an ArcCurve - but there’s an internal flag to indicate whether to treat it as a polygon or arc.
In the Ruby API there is an method for that: Class: Sketchup::Curve — SketchUp Ruby API Documentation
Turns out that the C API SUCurveGetType is an entity type check. The polygon flag appear to be omitted.
I logged this as an issue: C API missing function to detect polygons · Issue #194 · SketchUp/api-issue-tracker · GitHub
I wasn’t able to find any workarounds I’m afraid.
