good points, that .normalize!
is pirated straight from the API, which we know should be taken with a grain of salt…
hi @TIG, did you find the latest rbz at SCF?
any other things that might break earlier versions?
dave’s trying to make sea sick…
EDIT: I’ll add the code here for ease of reference…
I may as well use ORIGIN
for the circle and X_AXIS
for ang = vert1
as well…
# based on JF.draw_sine_wave by Jim Folts, with help from Jim Hamilton
module JcB
module SineCircle
extend self
@radius = 0.5.m
@segments = 96
@modulo = 6
@scale = 4
@keep_circle = 'Yes'
@cylinder = 'Yes'
@explode = 'Yes'
def single_wave
model = Sketchup.active_model
entities = model.active_entities
prompts = [' Circle @radius? ', ' Circle Segments? ', ' Wave Segments? ', ' Wave Height? ',
' keep Circle ', ' keep Cylinder ', 'Explode All? ']
defaults = [@radius, @segments, @modulo, @scale, @keep_circle, @cylinder, @explode]
list = ['', '', '', '1|2|3|4|5|6|7|8|9', 'No|Yes', 'No|Yes', 'No|Yes']
input = UI.inputbox(prompts, defaults, list, 'Sine Circle Details')
return unless input
@radius = input[0].to_l
@segments = input[1].to_i
@modulo = input[2].to_i
@scale = input[3].to_i
@keep_circle = input[4]
@cylinder = input[5]
@explode = input[6]
if @segments.modulo(@modulo) != 0
UI.messagebox('Use Number of Circle Segments that are divisible by the Number of Wave Segments')
p 'retry'
single_wave
else
# wrap geometry creation in an undo...
Sketchup.active_model.start_operation('Sine Circle')
circle_grp = entities.add_group
circle_gents = circle_grp.entities
# create the base circle perpendicular to the normal or Z axis
edges = circle_gents.add_circle(ORIGIN, Z_AXIS, @radius, @segments)
# p edges.first.length.to_mm
# collect the verts
verts_ary = []
edges.first.curve.vertices.each { |vert| verts_ary << vert.position.to_a }
edges.each(&:find_faces) rescue edges.each{|i| i.find_faces}
face = circle_gents.grep(Sketchup::Face)[0]
face.reverse!
face.pushpull(@radius) if @cylinder == 'Yes'
unless @keep_circle == 'Yes' || @cylinder == 'Yes'
entities.erase_entities(circle_grp)
end
# p verts_ary.length
# add the new vert positions
i = 0
new_pts = []
segs = @segments / 2
verts_ary.each do |vert_pos|
i += 1
ang = X_AXIS.angle_between(vert_pos)
height = @scale * Math.sin(@modulo * ang)
if i <= segs # of base circle
new_pts << (vert_pos[0..1] << height)
else # flip
new_pts << (vert_pos[0..1] << -height)
end
end
# make the curve
grp = Sketchup.active_model.active_entities.add_group
gents = grp.entities
gents.add_curve(new_pts)
point = Geom::Point3d.new(0, 0, @radius / 2)
t = Geom::Transformation.new point
grp.move! t
end
if @explode == 'Yes'
grp.explode
circle_grp.explode unless circle_grp.deleted?
end
Sketchup.active_model.commit_operation
end
end # def single_wave
end # module SineCircle
end # module JcB
unless file_loaded? 'sine_circle.rb'
# create toolbar
tb = UI::Toolbar.new 'Sine Circle'
# menu item
menu = UI.menu('Plugins', 'Sine Circle')
cmd = UI::Command.new('Sine Circle') { JcB::SineCircle.single_wave }
cmd.tooltip = cmd.status_bar_text = 'create sine waves on cylinders...'
cmd.large_icon = cmd.small_icon = File.join(File.dirname(__FILE__), 'sine_circle.png')
menu.add_item(cmd)
tb.add_item(cmd)
# showing the toolbar
tb.get_last_state == -1 ? tb.show : tb.restore
file_loaded('sine_circle.rb')
end # unless
john
