Sending json post request in thirdparty api from sketchup
I am trying to send a post request from sketchup to the api i made.I have web dialog.On the web dialog,On click the “save” button the post request will be executed.I want to send the information as json.I have been able to access the api i made.How can i access the length,width and send the length,width,volume from the sketchup model as json.here is the model i wrote:
  def self.show_dialog
    @dialog ||= self.create_dialog
    @dialog.add_action_callback("ready") { |action_context|
      self.update_dialog
      nil
    @dialog.add_action_callback("accept") { |action_context, value|
      self.update_material(value)
      @dialog.close
      nil
    @dialog.add_action_callback("cancel") { |action_context, value|
      @dialog.close
      nil
    @dialog.add_action_callback("save") { |action_context, value|
      request = Sketchup::Http::Request.new("http://127.0.0.1:5000/api/v1/projectStatus/save",  Sketchup::Http::POST              )
      request.start do |request, response|
        puts "body: #{response.body}"
      end
      nil
    @dialog.show
  end
I want send the the post request something like this:
    "length": "11",
     "width": "12",
    "volume": "168"
Please post code correctly on the forum (and make tabs are converted to spaces [2 for Ruby, 4 for other languages.)] SEE …
Well then you’ll either need to set that JSON as the request body or the request headers.
SketchUp’s Http::Request class takes a Ruby hash to set headers. It is really dead simple to convert between several hashlike Ruby classes and JSON object strings using Ruby’s JSON library.
json_text = '{
    "length": "11",
     "width": "12",
    "volume": "168"
hash = JSON.parse(json_text)
req = Sketchup::Http::Request.new(
  'http://127.0.0.1:5000/api/v1/projectStatus/save', Sketchup::Http::POST
req.headers= hash
# ... etc. ...
Or … if using the body (same json_text string) …
req.headers= { 'Content-Type' => 'application/json' }
req.body = json_text
# ... etc. ...
I’m not sure if you are asking where to get this information so I’ll give an answer for the model bounding box …
model_properties = {}
model = Sketchup.active_model
bb = model.bounds
model_properties['height']= bb.height
model_properties['width']= bb.width
model_properties['depth']= bb.depth
model_properties['volume']= bb.height * bb.width * bb.depth
json_text = model_properties.to_json
REF:
If you are interested in more precise total volume of actual components used, it will require iterating through the model and summing the volumes of manifold groups and components.
yes that what i was asking for.I am new to both skechup and ruby.Thats why couldnot explain it in a better way.
I think most likely you’d send custom json (like this) in the request body, rather than mess with custom headers.
