… and not to make the title to long this glued component contains a dynamic component…
That was the minimum which I needed to recreate the problem so I believe it is not only my file crushing…
Explanation…
Like it the title and first line…
In Top line Component, bottom is a Group. Right window gluing component containing this dynamic frame element…
I will scale only the selected blue ones by 0.5
Then magic happens…
So all of them are now unique cos I scaled a comp with DC in it… But as with Comp there seems to by no other error then the window and its location on the wall being scaled twice,. then with a group it is more puzzling or explains sth to some sage… Group being scaled didn’t actually scale except for its origin point and window size and location… Group which I didn’t touch scaled to 0.5 and window twice…
Actually it was more complicated when I scaled entire building, but could not actually reproduce other issues…
before
after
Walls were auto-folding strangely but still I couldn’t select anything behind original surface… like sKetchup internally and me on screen were seeing different things…
Probably known issue but couldn’t find anything… is there a work around ? except not using DC…
Test Recreated.skp (110.3 KB)
Testing Testing.skp (114.7 KB)
