Scale Definition all model components via Ruby
Continuing the discussion from "Scale Definition" via Ruby:
I made this code that rescale all the textures of the model, its works but take long due its iterating the definition’s instances twice, I’veen noticed, it also have identation problems, but as I’m not a programer I couldn’t rewrite it.
I’ll apreciate if someone can give me hand here:
instance = Sketchup.active_model.definitions.each do |definition|
definition.instances.each do |instance|
old_transformation = instance.transformation
# We now create a new transformation that uses the origin and axes directions,
# but normalize them to unit vectors (removes the scaling).
new_transformation = Geom::Transformation.axes(
  old_transformation.origin,
  old_transformation.xaxis.normalize,
  old_transformation.yaxis.normalize,
  old_transformation.zaxis.normalize
# Represents the difference between the old and the new desired transformation.
transformation = new_transformation.inverse * old_transformation
instance.definition.instances.each do |i|
  i.transformation *= transformation.inverse
end
entities = instance.definition.entities
entities.transform_entities(transformation, entities.to_a)
end
end
Thanks.
The code properly indented …
... (click to expand) ...
    # directions, but normalize them to unit vectors (removes the scaling).
    # Double iteration below ...
    end
  end
end
Also the instance = assignment on the first line (as you have it) will not be pointing at any instance. The #each iterator for a collection always returns that collection object when done. So the reference would be pointing at the active model’s DefinitionList object.
Thanks DanRathbun, it works much better.
Really?
Strange as I did not really change anything, but added some spaces to the start of a few lines.
I would have thought that …
    end
… should be replaced with …
    instance.transformation *= transformation.inverse
But I didn’t have a model to test on.
Hi!
I was looking for something similar for my plugin, its code works well but it takes a long time, I made a filter with a specific attribute in my component, it’s very fast now.
