When i rending , i saw “Warning : Lens effects skipped:no filter image.” Have anyone know ?
What rendering application are you using?
What operating system? “3” is not an operating system.
I used vray
You should have put that in your original post. I moved your thread to the Vray category.
I can’t read the log well enough due to its size. What camera or lens effects have you tried to use? Are you using CPU or GPU rendering? Maybe the problem comes from your “3” operating system.
[20:40:35.579] Warning : Forcing caustics mode to Progressive. It is the only mode supported in IPR.
CPU rendering . what’s 3 operating system?
In your forum profile.
The more information you give, that is correct, the faster someone like @DaveR can help you.
(post deleted by author)
Windows 11
¯_(ツ)_/¯
how can i adjust the light? i have read the teaching version. but the photo is very dark…
Please post a screenshot of your render as well as your render, camera, and lighting settings so we can actually see what you’re describing.
