Hi all,
I do a ruby extension that work on my mac.
I sign and script my extension on Sign Extension | SketchUp Extension Warehouse
Sadly a part of my code doesn’t work when I use the new rbz file. (mac os x, SU2020pro)
module Adebeo::Simpletool
class Tool
def initialize
@model=Sketchup.active_model
@colorSurbrillance1 = Sketchup::Color.new('green')
end
def draw(view)
return if view.nil?
view.drawing_color = @colorSurbrillance1
end
def function
if @model.selection
end
end
The console show
Error: #<TypeError: no implicit conversion to Color>
/users/…rbe:445:in `drawing_color=’
or
Error: #<NoMethodError: undefined method `selection’ for nil:NilClass>
@ variable have been turn to nil ?
Thanks for your help.
If you can link a ressource on rbe prerequise
This indicates that the model object is not yet ready on MacOS platform.
I would think this could be caused by activating the tool during the SketchUp startup cycle (which is a “no-no”.)
The weird thing is that the Tools collection and the View are objects belonging to the active model, so how could a Ruby tool get activated ?.
emmmmm to be frank since SU2019 I always type out literally Sketchup.active_model in every block…
Thanks dan for your answer,
Sorry for two things:
I forget to mention that the tool works normally. My message was not clear. Your message give me the idea why it did work. It was a small typo in the initialize function of my tool. I was suspected the rbe because it was the first use for me.
I don’t understand “no-no”
Thanks !
I use @model since 2010, it was a typo. sorry for disturbing you
“no-no” = “do not do this”
So this issue is solved?
And the topic title is misleading then (the issue is not related to RBE encryption)?
