Hi,
Im using Sketchup 2019,1,173, pro french release on mac OS. 10,14,4.
I have a component instance (with transformation) that contain one group (with a transformation) that contain one line.
In ruby console I do:
puts Sketchup.active_model.entities[0].definition.entities[0].entities[0].start.position
(1852 mm, 1,246711 mm, 725,992349 mm)
I double clic two time on the component and the group to enter and redo the command line
(49,443298 mm, 45,231205 mm, -81,507651 mm)
after I select the edge and do:
Sketchup.active_model.selection[0].start.position
The first and last method return the xyz from the origin of the model the second from the component.
Can someone clarify when position are relative or absolute?
What is the best pratice in ruby? Use the first method and apply transformation ?
Thanks for your help
