Rafa
March 8, 2023, 11:29am
1
I added a paypal to my website using javascript sdk (server is using Django)
There is no problem to load that website using Html:Dialog and display paypal functions.
The problem begins, when I click ‘PayPal’ button.
After click it I have new window like this:
‘Get an app to open this ‘about’ link’
On the DevTools, I found ‘popup_open_error_iframe_fallback’, maybe it is a clue.
I wonder if there is a way to allow paypal to open iframe from SketchUP.
Any ideas?
In the example I used Sketchup 2022.
ps. everything is working fine when I am using standalone browser
DaveR
March 8, 2023, 12:15pm
2
Why are you adding a PayPal window in SketchUp?
Your profile says you are using SketchUp 2017 Make.
Rafa
March 8, 2023, 2:31pm
3
Thanks for joining the discussion!
We are developing plugin which is connected with the web platform.
So for example…
user makes building using our plugin
load the project into web (using html:dialog)
we want add paypal integration to unlock files which is used to fabricate the model
I was wondering if it is possibility to do this in html:dialog.
If it isn’t we will request users to use external browser to make payment.
I installed 2022 trial to check if the problem is still exists. (2017 have pretty old browser)
That’s why I made a notice
DaveR
March 8, 2023, 2:35pm
4
Since you’re using SketchUp commercially–developing commercial extensions with it, you should be using SketchUp Pro, not Make.
tt_su
March 8, 2023, 3:11pm
5
UI::HtmlDialog doesn’t support the HTML page creating a new window. If the PayPal checkout require that you probably have to redirect the user to a normal browser window for that payment process.
What you tried was a cross origin request. See …
Cross-origin resource sharing (CORS) is a mechanism that allows restricted resources on a web page to be requested from another domain outside the domain from which the first resource was served.
A web page may freely embed cross-origin images, stylesheets, scripts, iframes, and videos. Certain "cross-domain" requests, notably Ajax requests, are forbidden by default by the same-origin security policy. CORS defines a way in which a browser and server can interact to determine whether it is safe t...
The Chrome Embedded Framework (used by the UI::HtmlDialog class,) is much more secure than a normal Chrome browser.
CEF enforces same-origin policy because (I think) the dialog pages have the origin http://localhost.
In computing, the same-origin policy (SOP) is an important concept in the web application security model. Under the policy, a web browser permits scripts contained in a first web page to access data in a second web page, but only if both web pages have the same origin. An origin is defined as a combination of URI scheme, host name, and port number. This policy prevents a malicious script on one page from obtaining access to sensitive data on another web page through that page's Document Object Mo...
You could have your dialog open a webpage in the user’s default browser using the UI.openURL() module method.
Rafa
March 9, 2023, 9:29am
8
Thanks for detailed information!
CEF enforces same-origin policy because (I think) the dialog pages have the origin http://localhost .
It was using test server, so it was not localhost, but that was nice guess.
In summary… probably I will upgrade workflow to use UI.openURL() instead.
Thanks for all answers!
