I created an object (a board with thickness) and then later added an offset to it so that I could place it on my buildings easily with the correct gap between panels. When I try to push/pull the object the offset does not move with it. What am I missing?
Only with the extension Joint PushPull (maybe some other extension as well?) can more than one face be push-pulled at a time. The native tool only push-pulls one face at a time. You CAN select more than one face and simply use the MOVE tool to move them at once, but that is a different operation. It could have the same result as push pull in some circumstances.
I forgot to make my copy unique and now I’m wondering why the rescale didn’t apply to the other sheets? The way it worked out was the intended result, just curious.
Scaling a component only affects that component. It doesn’t show in the others. If you open the component for editing and scale the geometry, you are modifying the component definition so the change will show in any other instances of the component.
Note that scaling the component instead of the geometry inside it does not change the definition unless you right click on it and choose Scale Definition.
