Hello
I have a closed point curve, when I do an “offset 2d path” with the “meter” option.
The list of points is not in the same order as the list of points in the original curve.
I add a node “shift list” to shift by -1 the liste of points.
If I edit my curve with parameters that adds or removes points and changes their positions. I sometimes need to change the value of the shift to be able to find the correct order.
Is there a rule to provide for the modification to be made to the shift?
Because I must add an “integer node” to visually correct the value of the “shift” and it’s not pro!
Thanks for your feedback.
