Hi all,
I’m experiencing some crashes on my SketchUp 2026 (and 2025) on both Mac and Windows. I only have my extension Addesign installed.
I suspect observers are the cause. I have InstanceObserver, EntityObserver, and EntitiesObserver implemented in my extension.
When I read the documentation, I found this note:
Note:
The methods of this observer fire in such a way that making changes to the model while inside of them is dangerous. If you experience sudden crashes, it could be because of this observer. A potential workaround is to use a ToolsObserver to watch what the user is doing instead.
My observers’ goals are:
Identify when a wall (component instance) is moved or deleted → so other walls can adjust their sizes, and windows can follow the wall (window components aren’t inside walls)
Identify when a window (component instance) is moved or deleted → to move or remove the opening
Identify when a window’s size changes (component definition) → to change the wall opening
Crashes happen suddenly but particularly when the user double-clicks on a group or a component (even if the component doesn’t have any link to any wall or window where observers are attached).
Is there a workaround for observers?
Any advice?
