NESTING software?
Hi. I have some irregular pieces in my model, that are places at odd angles. What is the fastest way to make production drawings from it? I guess there must be a way to avoid copying and positioning along the axes to find out where to cut the plates that I have in stock.
It would be very usefull for stairs…
Try 2 free extensions below:
  1. Open Cut List: Extension | SketchUp Extension Warehouse
  2. ABF: ABF Extension (getabf.net)
I already use Open Cutlist. It is noy realy a nesting software. It fits the form (let’s say a rectangular) in a rectangle and then makes a fit’s this rectangular in a sawplan. So a lot of waste. I have seen deep nest, But cannot install it.
Maybe you can try Deepnest.
Let try ABF, it’s free and has nesting feature.
When I try to open it, it says: Deepnest cannot be openend because the “developper cannot be verified” or something like that. perhaps somewhere my safety settings need to be changed?
Schermafbeelding 2023-12-19 om 15.40.23
But the communication on the site is in a lnaguage that I don’t understand at all.
Please update your forum profile. Having correct info there is often essential to solving a problem for you!
What kind of computer are you running? Your forum profile says MOS. Does that mean macOS, and if so, what version? Also 512GB is not a kind of graphics card and is a highly dubious amount of video memory! Sounds more like the size of a disk.
You have to manually enable the Application from MacOS settings > Security panel.
Unfortunately ABF is Windows only.
Nesting Center is maybe easier to use.
https://webclient.nestingcenter.com/
don’t just double click it.
right click / open
it will as you if you’re sure that you want to do it, say yes.
then, in the future, it’ll be whitelisted, and you can open it as usual.
Thanks!
I have a Mac mini, with a very powerfull processor, never had any problem with speed at all.
I will update my profile, thank you.
