Namespace in Multiple .rb Files
I am creating an extension and it is time to split everything out into multiple files.
I have in my main file…
require 'sketchup'
require_relative 'Model1'
module MyNameSpace
  module MyModels
    def self.create_model1
      model1
    end
    unless file_loaded?(__FILE__)
      # add menu items
      menu_Models = UI.menu('Extensions').add_submenu('My Models')
        menu_Model1.add_item('Model 1') {self.create_model1}
    end
  end
end
and in the second file
def model1
end
After reading about namespaces I included the namespace and module names in the second file, as I had seen in other extensions.
It was all working until a SketchUp restart and I got an
“Error: #<NameError: undefined local variable or method model1 for MyNameSpace::MyModels:Module>”
[code]
module MyNameSpace
module MyModels
def model1
end
end
end[/code]
After tearing my hair out I removed the namespace and module references and after a SU restart it works again.
What have I misunderstood about namespaces and module names? If it means anything I am not using classes at all.
Also, is there a way to reset the Ruby interpreter so a SU restart is not required?
Hi,
I share on github my template for sketchup extension
At the top of your extension
create a module with your name as author
create a module with the name of your extension
module Adebeo
module ExtensionName
ISDEVELLOPPEMENT = true
end
end
inside another file create a class inside this 2 namespaces:
module Adebeo::ExtensionName
	class Controler
		attr_accessor
		def initialize()
			@model = Sketchup.active_model
			@definitions = @model.definitions
		end
	end
end
Please find a full exemple, here:
The Discourse forum engine does not use bbCode. See:
… becuase you ae defining the method in the global ObjectSpace, which is class Object. This means your method definition will get added to everything as everything in Ruby is an object of some class that inherits from Object.
And, of course it seems to work, as global methods are just that, accessible from every scope because they are insinuated into everything.
You have not yet understood the difference between instance methods and module methods.
In your first file, you define a module method that requires qualification (self.method_name or from outside … MyNameSpace::MyModels.method_name.)
In your second file, you define an instance method without qualification.
If you would like to call any method from within your submodule (in any of it’s files,) without qualification, then in the first file, at the top of the submodule, add a statement to mix the submodule into itself …
module MyNameSpace
  module MyModels
    extend self
    # Define instance methods ...
See: Object#extend
… and chapters on mixin modules in any good Ruby book.
Thanks Denis,
If I use
MyName::ExtName
I get uninitialized constant MyName
This is because the outer constant MyName is not yet defined and you are trying to define (or open for edit) the inner module ExtName.
There are 2 workarounds …
1. Use nested definitions for the first file:
module MyName
  module Extname
2. Just before the nested definition, for the first file, insert a blank module block:
module MyName; end
module MyName::Extname
Hi Dan,
workaround 1 is how I initially had them (nested)
Uh…huh, so use (2) if you want to gain an indent.
Keep in mind that your first file, will actually be the extension registrar script that goes in the “Plugins” folder. All other files go in the extension’s subfolder. (The subfolder and registrar script must have the same name.)
Example registrar file:
module CoyoteToolworks
  module CrazyWidget
    EXTENSION ||= SketchupExtension.new('','main')
    EXTENSION.instance_eval do
      self.name        = 'Crazy Widget Tool'
      self.version     = '1.3.0'
      self.creator     = 'Coyote Toolworks, Ltd.'
      self.copyright   = '©2020, by author.'
      self.description = 'Draws widgets faster than a roadrunner.'
      Sketchup.register_extension(self,true)
    end
  end
end
At the moment I am just calling load in the console on the first file during development.
The file I am calling first is not the file I would put in the plugins folder. It is the file that creates menu items and will call functions defined in other files as a result of menu choices.
I am guessing I have some stupid error I can’t see…
Your extension files can have whatever name you wish. (Many devs use names like “menu.rb” and “gui.rb” for the file that defines UX commands and such.)
You can also name the “loader file” (ie, the 2nd argument to the SketchupExtension constructor,) whatever you wish. (I myself use “loader”, many devs use “main”. :shrug:)
What error ?
If only I knew …
my menu file
require 'sketchup'
# require 'extensions'
# require 'Icosahedron'
require_relative 'Icosahedron'
#require_relative 'Test'
module BHL
  module Polyhedrons
    def self.create_icosahedron
      if not @frequency
        @frequency = 1
      end
      prompts = ["Frequency"]
      values = [@frequency]
      list = ["1|2|3|4|5|6", @frequency]
      results = UI.inputbox(prompts, values, list, "Frequency")
      return if not results
      @frequency = results[0]
      if @frequency == 1
        icosahedron_CIV1
      elsif @frequency == 2
        icosahedron_CIV2
      elsif @frequency == 3
        icosahedron_CIV3
      end
    end # self.create_icosahedron
    def self.octahedron
      UI.messagebox "Octa coming later"
    end # self.create_octahedron
      menu_Poly = UI.menu('Extensions').add_submenu('Polyhedrons')
        menu_Icosa = menu_Poly.add_submenu('Icosahedron')
          menu_Icosa.add_item('Icosa Class I') {self.create_icosahedron}
          menu_Poly.add_item('Octahedron') {self.octahedron}
#        menu_Poly.add_separator
 #       menu_Poly = UI.menu('Extensions').add_submenu('Test')
  #        menu_Poly.add_item('Test Output Box') {self.test_output}
      file_loaded(__FILE__)
    end # unless file_loaded?(__FILE__)
  end # module Polyhedrons
end # module BHL
worker file
module BHL
  module Polyhedrons
    def get_icosa_vtxs(radius)
      #  phi = (Math::sqrt(5) + 1) / 2
      #  atanPhi = Math::atan(Phi)
      pi = Math::PI
      atan_2 = Math::atan(2)
      vtx_X_1 = radius * Math::sin(atan_2) * Math::sin(0.4 * pi)       # e
      vtx_X_2 = radius * Math::sin(atan_2 / 2)                         # s
      vtx_Y_1 = radius * Math::sin(atan_2)                             # b
      vtx_Y_2 = radius * Math::sin(atan_2) * Math::cos(0.4 * pi)       # f
      vtx_Y_3 = radius * Math::sin(atan_2) * Math::sin(0.3 * pi)       # c
      vtx_Z_1 = radius * Math::sin(atan_2) / (2 * Math::sin(0.3 * pi)) # d
      arr_Vtxs = Array.new(12)
      arr_Vtxs[ 0] = Geom::Point3d.new(         0.0,         0.0,        radius.m) #  0,  0,  r
      arr_Vtxs[ 1] = Geom::Point3d.new(         0.0, - vtx_Y_1.m, (1 - vtx_Z_1).m) #  0, -b,  r - d
      arr_Vtxs[ 2] = Geom::Point3d.new(   vtx_X_1.m, - vtx_Y_2.m, (1 - vtx_Z_1).m) #  e, -f,  r - d
      arr_Vtxs[ 3] = Geom::Point3d.new(   vtx_X_2.m,   vtx_Y_3.m, (1 - vtx_Z_1).m) #  s,  c,  r - d
      arr_Vtxs[ 4] = Geom::Point3d.new( - vtx_X_2.m,   vtx_Y_3.m, (1 - vtx_Z_1).m) # -s,  c,  r - d
      arr_Vtxs[ 5] = Geom::Point3d.new( - vtx_X_1.m, - vtx_Y_2.m, (1 - vtx_Z_1).m) # -e, -f,  r - d
      arr_Vtxs[ 6] = Geom::Point3d.new(   vtx_X_2.m, - vtx_Y_3.m, (vtx_Z_1 - 1).m) #  s,  c,  d - r
      arr_Vtxs[ 7] = Geom::Point3d.new(   vtx_X_1.m,   vtx_Y_2.m, (vtx_Z_1 - 1).m) #  e,  f,  d - r
      arr_Vtxs[ 8] = Geom::Point3d.new(         0.0,   vtx_Y_1.m, (vtx_Z_1 - 1).m) #  0,  b,  d - r
      arr_Vtxs[ 9] = Geom::Point3d.new( - vtx_X_1.m,   vtx_Y_2.m, (vtx_Z_1 - 1).m) # -e,  f,  d - r
      arr_Vtxs[10] = Geom::Point3d.new( - vtx_X_2.m, - vtx_Y_3.m, (vtx_Z_1 - 1).m) # -s, -c,  d - r
      arr_Vtxs[11] = Geom::Point3d.new(         0.0,         0.0,      - radius.m) #  0,  0, -r
      arr_Vtxs
    end # get_icosa_vtxs(radius)
    def icosahedron_CIV1
      # This method creates an icosahedron within a component in the model.
      arr_Face_Map = [[0, 1,  2], [0, 2,  3], [0, 3,  4], [0,  4,  5], [0,  1,  5],
                      [1, 2,  6], [2, 6,  7], [2, 3,  7], [3,  7,  8], [3,  4,  8],
                      [4, 8,  9], [4, 5,  9], [5, 9, 10], [1,  5, 10], [1,  6, 10],
                      [6, 7, 11], [7, 8, 11], [8, 9, 11], [9, 10, 11], [6, 10, 11]]
      radius = 1.0
      arr_Icosa_Vtxs = get_icosa_vtxs(radius)
      Sketchup.file_new
      model.start_operation('Create Icosahedron', true)
      component = model.definitions.add
      component.name = "Icosahedron"
      entities = component.entities
      # add faces
      arr_Face_Map.each do |face|
        component.entities.add_face(arr_Icosa_Vtxs[face[0]], arr_Icosa_Vtxs[face[1]], arr_Icosa_Vtxs[face[2]])
      end
      transform = Geom::Transformation.new([0, 0, 0]) # an empty, default transformation.
      model.active_entities.add_instance(component, transform)
      model.commit_operation
    end # icosahedron_CIV1
    def icosahedron_CIV2
      UI.messagebox "Icosa V2 + coming later"
    end # icosahedron_CIV2
    def icosahedron_CIV3
      UI.messagebox "Icosa V3 + coming later"
    end # icosahedron_CIV3
end # module BHL
I solved your error (unqualified method calls) for you above …
… also, the ol’ “Pick Axe” Ruby book suggests using blank () at the end of method calls when there are no arguments. (It helps the interpreter to immediately know that this is a method call and not a local variable reference. So the interpreter does not have to do a search though the scope to determine what it is, … a method reference or a variable reference.)
Ie …
if @frequency == 1
        icosahedron_CIV1()
A tidbit, … Ruby has modifier position conditionals …
@frequency = 1 if not @frequency
Ruby also has conditional assignment …
@frequency ||= 1
… (but keep in mind you cannot use this for boolean references.)
Thanks Dan,
extend self has fixed it.
I tried method 2 but didn’t successfully qualify the call. I tried MyName::Extname::icosahedron_CIV1 and
MyName::Extname.icosahedron_CIV1
I appreciate the tidbits. The conditional assignment is interesting.
There is a lot to learn with Ruby. A lot of different ways to do things and quite some difference to what I am used to. I get brain strain.
