medeek
1
I can’t seem to find any threads on this topic but it may have been answered before.
I’m trying to figure out if there is way to generate multi-line 3D text with the API.
Can I insert a newline character or some other special character that will cause the API to create multiple lines of text?
dezmo
2
\n
def test_text(text)
entities = Sketchup.active_model.entities
entities.add_3d_text(text, TextAlignLeft, "Arial")
end
test_text( "my\ntest")
dezmo
3
BTW
It is important to use " double quotes to define the string, otherwise :
medeek
4
Thank-you, this is very exciting, I didn’t realize I could do multi-lines with the 3D text.
This can be fixed inside the method …
def test_text(text)
entities = Sketchup.active_model.active_entities
text.gsub!('\n',"\n")
end
medeek
6
On a related note does anyone know what the actual integer values are for the constants:
TextAlignLeft
TextAlignRight
TextAlignCenter
I can’t seem to find this anywhere in the documentation.
Sketchup defines these constants at the top level NameSpace
You can simply type the name into the Ruby Console to retrieve the value.
TextAlignLeft = 0
TextAlignCenter = 1
TextAlignRight = 2
Or , in any Module you can look up the value of a single constant with the const_get() method using name of the constant as a Symbol.
Object.const_get(:TextAlignCenter)
or dump the gamut
Object.constants.sort.each { | const |
puts "#{const} = #{ Object.const_get(const) }"
nil
Object being the default root of all Ruby objects.
Tomtom has produced a plugin that allows the insertion of editable multiline 3D text.
