Moving a section plane using ruby
is it possible?
copilot says yes:
"# Sélectionner le plan de section
model = Sketchup.active_model
entities = model.active_entities
section_planes = entities.grep(Sketchup::SectionPlane)
if section_planes.any?
section_plane = section_planes.first
Définir une nouvelle transformation pour déplacer le plan
translation = Geom::Transformation.new([10, 0, 0]) # Déplace de 10 unités sur l’axe X
section_plane.transform!(translation)
puts “Le plan de section a été déplacé.”
else
puts “Aucun plan de section trouvé dans le modèle.”
end
but it is AI hallucination
sketchup documentation says transform! is only for groups and components
so is there another way?
I haven’t tried it, but maybe SectionPlane#set_plane is what you want.
i tried: the example in sketchup documentation:
"model = Sketchup.active_model
Grab the first section plane from the model.
sp = entities.grep(Sketchup::SectionPlane).first
sp = sp.set_plane my_plane_array"
gives an error…
"“Wrong number of arguments for plane”
That sounds like you didn’t create plane array correctly. What did my_plane_array have in it? It should be an Array of one Geom::Point3d and one Geom::Vector3d, or an Array of four numbers that “give the coefficients of a plane equation”.
Edit: in case that vague API doc statement isn’t clear:
  • if you pass an Array of [Geom::Point3d, Geom::Vector3d] the point is any point on the plane, and the vector is the normal vector to the plane.
  • if you pass an Array of four numbers, they are the coefficients [a,b,c,d] of the 3d plane equation ax+by+cz = d
Yes, the AIs often “invent” methods and functions that do not exist.
They also think that anything posted to a public forum is gospel truth, instead of checking official sources like API documentation.
Also, @glro please post code correctly in the forum:
i have tried this:
pt1 = Geom::Point3d.new
pt2 = Geom::Point3d.new(0,0,10)
vec = pt1 - pt2
my_plane_array = Array.new
my_plane_array.push pt1
my_plane_array.push vec
if entities.grep(Sketchup::SectionPlane).length >=1
	# Grab the first section plane from the model.
	else
	UI.messagebox "no section plane in the model"
end
it works:
from this
to this
the section plane is moved to the origin
by changing pt1 coordinates, it would be possible to move the section plane; i would never have understood that alone, thank you
I found another way to move a section plane, n this case along a points cloud.
create a scene with the points cloud, add a section plane on the other side of the points cloud, inactivate it and save the scene.
create a second scene, activate the section plane and save the scene.
make sure the animation parameters are set with a transition between scenes
also make sure that, in ‘scan essentials’ points cloud manager window , show a box of points around section plane, is on.
Now when you switch scenes, a slice of points is shown, moving from trom one side to the other
https://vimeo.com/1078904633?share=copy
