Medeek Truss
Added Bowstring truss type, configurations: (8/8).
View model here:
28’ Bow Barrel Truss (8/8) study.
View model here:
Gable end trusses for this type are a bit of a question right now. I can add this one into the plugin if there is some call for it, but I may hold off until a request is made since the code will be somewhat tedious with all the separate members that make up the top and bottom chords.
Version 1.3.4 - 03.02.2016
  • Corrected a bug in the metric unit template module.
Version 1.3.5 - 03.04.2016
  • Added Bow Barrel truss type, configurations: (8/8).
  • Metric input enabled for bow barrel truss type.
  • Corrected a bug with the webs of the bowstring truss type.
View model here:
[url]https://3dwarehouse.sketchup.com/model.html?id=u754b5fc3-c3ea-48cb-9f13-24c92ae39d97[/url]
Gable end option is also available (not shown in image above for clarity) for this truss type.
I find the bow barrel truss very interesting. Its very similar to a flat truss in a lot of respects but then you essentially create pitch breaks at all the panel points and add some camber to it.
View model here:
I’m thinking the next thing I might tackle is an octagonal rafter roof. Something along these lines:
My time allotted to work on the plugin is very limited right now so I’m trying to decide if this would be something of interest for current and potential users of the plugin.
Version 1.3.6 - 03.06.2016
  • Added Double Howe and Triple Howe common truss types.
  • Structural outlookers (vert. & horz.) enabled under advanced roof options for Common (Double & Triple Howe) truss types.
View model here:
Nine different truss profiles currently available within the Medeek Truss Plugin:
  • Common
  • Attic
  • Monopitch
  • Scissor
  • Tail Bearing
  • Dual Pitch
  • Bowstring
  • Bow Barrel
  • Floor (System 42)
View model here:
Are there any truss types I am missing that you would like to see added to the plugin?
Version 1.3.7 - 03.06.2016
  • Added Soffit Cut within Advanced Options for common fink truss type.
After I’m certain that this feature is robust I will add it to all other truss types and rafter roofs. For now it only applies to roofs that use a common fink truss (non-raised heel).
Here is one way to frame an octagonal roof. The basic hip elements were first created with the plugin. This is a study of this type of roof to see what is required to add it into the plugin:
View model here:
[url]https://3dwarehouse.sketchup.com/model.html?id=u27fa9eb4-683a-4d0e-b77c-17427a401b6b[/url]
Another method would be to use an 8 faceted center block. Dewalt’s framing book goes into some alternative methods in some detail. I prefer the method I have shown above because it is much easier to extrapolate the framing method to include elongated octagonal roofs. 8 common rafters and 8 hip rafters come together at the peak, seems like it would be a real pain to try and fasten these at the peak, perhaps someone could enlighten me on how a carpenter would actually put this together.
Perhaps something like this.
16 sided compression ring
Shep
The true “octagonal” facet was popular 10 years ago; looks pretty, but is a waste of internal space. As a compromise, we now build a similar roof with a stretched front face (so that the proportions of the front are twice that of the corner facet) - this makes the roof pitch over the two corners a bit shallower. Still looks nice, but has a bit more usable internal space.
{… although in theory you could have two hips coming together 2/3 of the way up the roof and one hip from that point to the crest…}
The other variant on a theme is a dodecagon (120º angles rather than 135º)
Do you have any dimensions of the floorplan and / or roofing plan of these modified octagonal roofs?
The question I would like to ask the SketchUp community is: Is this plugin something you need or would like to see? Is this plugin potentially useful to you as a SketchUp User?
If the answer is “no”, then I have other ideas for plugins that I can divert my attention to.
If the answer is “yes”, then I would like to continue developing this plugin and spend as much of my free time as possible to accelerate its development.
Here is the one question survey:
Version 1.3.8 - 03.10.2016
  • Added wireframe (temporary) graphics to the truss positioning tool.
  • Added Boise Cascade BCI® I-joists: 4500, 5000, 6000, 6500, 60, 90.
  • Rim joist option enabled for BCI floor joists.
  • Removed drop down list for all overhang lengths (truss & rafter roofs). Overhangs are now users inserted values.
The screenshot above shows the wireframe that is displayed for common truss types.
A request by a potential user has got me thinking about Vulcraft (steel) and RedBuilt (steel and wood) open-web trusses for commercial applications. I noticed that on both of their websites they have either Revit models or Revit add-ins for generating their product geometry within Revit. I have contacted both companies about obtaining geometry for SketchUp. Does anyone have any other commercial truss products that they use on a regular basis?
This is a study of hip roof framing where unequal pitches meet at the hip (90 deg. to each other). In this case the birdsmouth cut is 3.5" for all jack and common rafters. The hip rafter is dropped and off center so that it lines up with the roof planes.
I assumed that the governing design criteria was that the sub-fascia line up hence the steeper pitch roof has a smaller overhang.
View model here:
I haven’t gone through and created the calculations yet for the plugin but the one thing that jumped out at me was the necessity to offset the hip rafter slightly from the hip centerline when a dropped hip rafter is employed. Please review the model and let me know if there are any problems with the way this comes together.
Another study of hip roof framing where unequal pitches meet at the hip. The birdsmouth cut is 3.5" for all jack and common rafters. The hip rafter is dropped and off center so that it lines up with the roof planes. The hip roof combines a 12:12 pitch with a 6:12 pitch.
View model here:
Version 1.3.9 - 03.14.2016
  • Out-to-out span of trusses in the trial version are now limited to a range of: 16 ft. (5m) - 32 ft. (9m).
