Material Take Off using Ruby
Well, your iteration will occur even when the definition has 0 instances and even with some instances will occur for definitions that have 0 used instances.
This iteration will skip definitions with no instances and no used instances:
def count_used_instances
  model = Sketchup.active_model
  puts "below are the definitions name and count"
  definitions = model.definitions
  those_used = []
  puts "--------------------------------------------"
  definitions.each { |definition|
    next unless definition.instances.size > 0
    num_used = definition.count_used_instances
    next unless num_used > 0
    puts "#{definition.name} : #{num_used}"
    those_used << [ definition.name, num_used ]
  # those_used is an array of nested [name, qty] arrays;
  # return it as a hash with the name as the keys, qty as the value:
  those_used.to_h
