hello, I have a table in excel with several columns and a rgb value.
I was wondering if it is possible to create a script that creates in the model all the colors of the table, taking the name and the RGB code.
Sure.
You can import the excel data into SU. There are several topic here about it:
https://forums.sketchup.com/search?q=excel%20%20%23developers%3Aruby-api
Once you have imported and, for example, assuming you have a hash of RGB names-values like
rgb_hash =
"55-3-Color1-193a" => [162,162,157],
"Other_color_name" => [1,2,255]
You can do somthing like this:
def create_materials(rgb_hash)
model = Sketchup.active_model
materials = model.materials
rgb_hash.each{|name, value|
new_material = materials.add(name)
new_material.color = value
end
# If there is already a material with the given name,
# then a new unique name is generated using the given name as a base.
Ref:
https://ruby.sketchup.com/Sketchup/Materials.html
https://ruby.sketchup.com/Sketchup/Material.html
https://ruby.sketchup.com/Sketchup/Color.html
