I have a bit of a problem with losing the connection to my web dialog. My web dialog is using a SelectionObserver to track what is being selected.
However, when I open a new model… I can no longer get the handle to the dialog window.
So here in this code…
class MySelectionObserver < Sketchup::SelectionObserver
def myDialog dialog
@gp = dialog
end
def onSelectionBulkChange(selection)
if @gp.dialog.visible?
@gp.update()
end
end
def onSelectionCleared(selection)
@gp.update()
end
end
end
class MyAppObserver < Sketchup::AppObserver
def onOpenModel(model)
if @gp != nil
// This block is where I would reinitialize my web dialog, however it never gets called as @gp is always nil....
else
puts "can't find it... the web dialog is now unresponsive..."
end
end
end
Sketchup.add_observer(MyAppObserver.new)
Thoughts on how I can maintain a persistent handle to a web dialog with a SelectionObserver?
You've listed a local variable named 'select'. If it's not an instance variable (@select), when the active model changes, the previous active model goes out of scope, and it's reference to 'select' goes away.
Does it work if you make 'select' into an instance variable, as in '@select'?
Of course, I assume you're re-attaching it to the new model, as I mentioned previously...
Greg
Thanks for your help–I figured it out. Essentially I had to find the right place to find the variable to be re-attached to the model. I had to get it from the point where I spawned the web dialog rather than in the initialization of said web dialog.
