Is it possible to do the following with Sketchup Ruby API?
Create plane (the plane is created on a mountains mesh).
Set Shadows hour.
Project the shadows onto the surface of the plane
Save the shadows on the plane as image
I would like to get white plane covered with gray shadows.
I ask because I would like to do it many times for different hours and different planes.
Don’t ask me why I want this. I would like to try some fancy things with masks… This is for image editing program.
Export with Ruby? But how to do the stuff with Shadows settings?
Ok, I add here the code needed to export the image, at least:
view = Sketchup.active_model.active_view
status = view.write_image "test.jpg"
keys = {
:filename => "c:/tmp/write_image.png",
:width => 640,
:height => 480,
:antialias => false,
:compression => 9.0,
:transparent => true
view.write_image keys
you can change shadowOptions = model.shadow_info.to_a
but if you want a shadow catcher @TIG has a plugin that creates geometry from them…
then you can set there materials. etc…
john
I can try to write some basic plugin. But how do you clear console?
tricky one…
SKETCHUP_CONSOLE.clear
you can also use the up arrow to bring up old versions to modify and try again…
even after clear…
john
Here is my first part of the plugin so far.
### http://ruby.sketchup.com/Sketchup/ShadowInfo.html
def barr_shadows
Sketchup.active_model.start_operation "Barracuda Shadows"
si = Sketchup.active_model.shadow_info
si["Light"] = 85;
si["Dark"] = 45;
### value = si["ShadowTime"]=Time.local(2017, 7, 21, 14);
value = si["ShadowTime"]=Time.gm(2017, 7, 21, 14, 00);
si["TZOffset"] = -1.0;
UI.messagebox value
si["EdgesCastShadows"] = false;
si["DisplayShadows"] = true;
Sketchup.active_model.commit_operation
return
end
barracuda_shadows = UI.menu("Plugins")
if not (file_loaded? "shadows.rb")
barracuda_shadows.add_item("Barracuda Shadows") {barr_shadows}
end
Everything except the hour of the day works. Hover is 12:00 instead of 14:00. Also the shadows seems to be cca 4x longer then normal.
barracuda:
Ah, but not in SU8
get a mac and v17 and then my answer will be correct… [sometimes]
I wrote a plugin that gives me all the ruby calls for changing the settings…
I have no idea if it can work on such a SU version running on XP…
maybe you can adapt it?
john
for clearing the console look >>>HERE<<<
john
I update the code and used #gm so I got correct time now. But the shadows are still longer. It could be because I am using UTC-1:00 instead UTC+1:00. The UTC+1:00 does not show shadows: This is not clear why it happens. I think I will measure real shadow tomorrow to see what is happening.
Is it possible to save the plane with textures projected on it’s surface? The reason why I would prefer to do it is that this would skip me the need to use raster editor to remove mesh.
it’s possible because both @TIG and @kirill200777 [maybe more] have done it in their extensions…
but I never have, so look at their code if possible and ask them questions if you get stuck…
john
I have found only Elev45shadows.rb from @TIG but AFAIK this does not include the functionality to generate texture or to make the shadow part of the texture.
TIG
July 18, 2017, 8:21pm
16
I know of nothing that will make a shadow part of a texture on a face…
This would be very complex to achieve - but for what end ?
The tool I made makes a separate face with a ‘gray’ transparent texture for each shadow cast…
It’s not intended to merge textures etc !
TIG-shadowProjector is the one I was thinking of…
john
TIG beat me to it…
The purpose was to get the image with dimensions of the plane and shadows on it. It would save me cropping of the image which I need to export.
TIG
July 18, 2017, 10:37pm
19
I’m sorry, but your explanations is still not entirely clear…
Can you try and explain your needs in simple steps…
I fear there is not a simple solution.
But until we have clarity, then who knows ?
I will write code tomorrow and show you what it does. Just wait till it be ready.
OK I measured the shadow and I corrected the UTC, set geolocation anow it it pretty close, but not exact.
value = shadowinfo["ShadowTime"]=Time.gm(2017, 7, 19, 12, 03);
shadowinfo["TZOffset"] = +1.0;
shadowinfo["Latitude"] = lat
shadowinfo["Longitude"] = lon
Eg. For UTC+1:00 (Middle Europe, Lat 49.779147, Lon 18.439736) The correct shadow length is 655:1160.
The shadows are 0,564 times longer (akka 2x shorter)
In SU8 I got the ratio
0,55950266429840142095914742451155
So there is cca -0,005 mistake.
Final code
def centerCamera(perspective = false, zoomOut = 150)
cam = Sketchup.active_model.active_view.camera;
cam.perspective = perspective;
Sketchup.send_action('viewTop:');
Sketchup.send_action('viewZoomToSelection:');
end;
def barr_shadows( ground=false )
si["Light"] = 85;
si["Dark"] = 45;
value = si["ShadowTime"]=Time.gm(2017, 7, 19, 12, 03);
### UI.messagebox value
si["TZOffset"] = +1.0;
si["Latitude"] = 40.779147
si["Longitude"] = 28.439736
si["DisplayOnGroundPlane"] = ground;
return
end
def write_img(width=800, height=600)
keys = {
:filename => "U:/tmp/01.png",
:width => width,
:height => height,
:compression => 0.9,
end
barracuda_shadows.add_item("Barracuda Shadows") { barr_shadows; centerCamera(); }
end
However - would it be possible to crop the image?
