I don’t think there’s a simple answer to this. There’s no direct solution to this in the Ruby API.
The .equals? method compares instances geometrically. It doesn’t say anything about scaling.
However, if you examine (compare) the transformation matrices of instances you can figure out the scaling.
The Transformation#to_a method retrieves a 16 element array which contains the values that define the transformation.
I have given up on this for now. There may be some simple logic associated with the matrix values and comparison checks, but it’s above my pay grade. The combination of rotation and scaling leaves me with too many uncertainties. I might come back to this when I better understand Ruby and I now what I want to achieve e.g. making modified components unique or just issuing an alert.
Anyway, I found a snippet that I saved a good few years ago… originally I think it was made by @thomthom : on https://community.sketchucation.com/
This can tell you if selected instance is flipped or not by any its axis…
module TransformationHelper
def flipped_x?
dot_x, dot_y, dot_z = axes_dot_products()
dot_x < 0 && flipped?(dot_x, dot_y, dot_z)
end
def flipped_y?
dot_y < 0 && flipped?(dot_x, dot_y, dot_z)
end
def flipped_z?
dot_z < 0 && flipped?(dot_x, dot_y, dot_z)
end
private
def axes_dot_products
xaxis.dot(X_AXIS),
yaxis.dot(Y_AXIS),
zaxis.dot(Z_AXIS)
end
def flipped?(dot_x, dot_y, dot_z)
dot_x * dot_y * dot_z < 0
end
end
module TestFlip
def self.inspect_flipped
tr = Sketchup.active_model.selection[0].transformation
tr.extend(TransformationHelper)
p tr.flipped_x?
p tr.flipped_y?
p tr.flipped_z?
end
end
TestFlip::inspect_flipped
In your observer instance, when you first attach it to an object (group or component instance) you can store the original transform (for later comparison) in an instance variable or in an attribute dictionary attached to the object.
# When a Group or Component is created the transformation matrix is
# initialized with unit vectors for the x, y, and z axes as
# represented by the following pseudo code.
# tr = Geom::Transformation.new(
# [1, 0, 0],
# [0, 1, 0],
# [0, 0, 1],
# model.selection.bounds.corner(0),
# As an object is scaled the matrix is adjusted to represent a 3D
# space where these axes are lengthened or shortened appropriately.
# We can detect this scaling in the matrix by createing an inverse
# transformation from the unit vector axes returned by the xaxis,
# yaxis, and zaxis methods of the transformation. Then multiply the
# two transforations, and compare the result to the IDENTITY matrix.
# Caveat: With this method we can not detect if the object has been
# scaled by exactly -1.0 in any direction. For those cases we must
# use the TransformationHelper developed by thomthom
model = Sketchup.active_model
ents = model.active_entities
# Grab the first entity in entities
tr_target = ents[0].transformation
puts
puts "Entity Transformation"
tr_target.to_a.each_slice(4) {|slice| p slice}
# Create a transformation that converts entity back to global space
tr_inverse = Geom::Transformation.axes(
tr_target.to_a[12..14],
tr_target.xaxis,
tr_target.yaxis,
tr_target.zaxis
).inverse
puts
puts "Inverse Transformation"
tr_inverse.to_a.each_slice(4) {|slice| p slice}
# un-rotate the target transformation
tr_result = tr_target * tr_inverse
# Round off accumulated floating point error
tr_result_arr = tr_result.to_a.collect {|v| v.round(12)}
puts
puts "Result Transformation"
tr_result_arr.each_slice(4) {|slice| p slice}
puts
# Compare the resulting transformation to the
# IDENTITY transformation
# See Note: https://ruby.sketchup.com/Geom/Transformation.html#identity%3F-instance_method
if tr_result_arr == IDENTITY.to_a
puts "The entity has NOT been scaled"
else
puts "The entity has been scaled"
end
