Hi everyone,
Im developping an extension for the company i work for.
basicly what the extension should do, is:
when the extension is launched a textbox should appear, prompting the user for the amount of pannels (the model) horizontally and veritcally. then i need the extension to Make a grid like structures with the right amount horizontal and vertical “copies”.
This is what i have now: but i’m struggeling finding a solution to set a specific location for the imported model.
thanks in advance
You have the right idea but the wrong API method. You want to load a ComponentDefinition
from a file into the DefinitionList
, then add an instance of the definition to the model at some location. Not tested, just going from memory…
model = Sketchup.active_model
definition_list = model.definitions
component_definition = definition_list.load('C:\Users\sande\Desktop\Bematrix skp plugin\606 ++++ ++++ 30.skp')
location = Geom::Point3d.new(0, 0, 0)
component_instance = model.active_entities.add_instance(component_definition, location)
Also the UI.inputbox
is “type-aware” meaning if the default types are String
objects then it returns String
objects, but if you use Integers you will get Integers back in the return value. This means defaults = ["1", "1"]
can be defaults = [1, 1]
Otherwise you need to convert the strings to integers like this: horizontal = input[0].to_i
Here’s a working example using arbitrary spacing along the X axis:
require 'sketchup.rb'
UI.menu("Plugins").add_item("Bemat Iwall") {
# load a component definition into the model's definition list.
defn = model.definitions.load('C:\Users\Jim\SketchUp\models\Wall.skp')
#Creating an input textbox for rows and columns
prompts = ["Horizontal", "vertical"]
defaults = [1, 1]
input = UI.inputbox(prompts, defaults, "Wall specifications")
vertical = input [1]
#for loop create multiple copies
for i in 0..horizontal
# add instances of the definition
model.active_entities.add_instance(defn, [i * 50, 0, 0])
end
Wow great answer, i think i get it now,
i am still not adjusted to the ruby api i guess haha
and i didn’t know this about the textboxes, i was going to try type casting it.
I’ll try this tomorrow as soon as i have the chance!
Kind regards.
