I need to choose from a list of 3 types of tubes, each one with a different thickness and weight.
Like this :
–Type 1 → Thickness 1.0 → weight 0.690
–Type 2 → Thickness 2.0 → weight 0.170
–Type 3 → Thickness 3.5 → weight 0.790
So, it i select type one, the other two attributes must come out.
The first part: THICK was solved, as i formulated “select from a list” and then write the type and widht,Therefore, if I select “type 1”, its thickness is chosen, with the “optionlabel” option.
attribute: type-> select from a list
Thickness: =optionlabel("type)
So far so good, now i need that “WEIGHT” to convert to the value previously mentioned.
I tried to solve it with IF, and i couldnt make it work,
i tried with CHOOSE, the two first options work fine but I can’t get it to work with the third option
=CHOOSE(type, 0.690, 1.170, 0,790)
the third comes out empty…
I show you the example in skp:
Tube EXAMPLE.skp (20.3 KB)
UPDATE:
In the meantime i did this:
type 1 - 1
type 2 - 2
type 3 - 3
and then i created an attribute called “thickness” and =CHOOSE(OPTIONINDEX(“type”),0.690,1.170,0.790)
so far it works, but all these suggestions are VERY useful to have in order to resolve these kind of issues, as i find the skechup tutorials quite basic and there are few videos online. i am going to try all these options
