hello,
when i a add an ies light, the tip of the light source is seen in the render, how do i hide it?
Is this an interactive or static render? If it’s interactive, try a static and make sure to enable Denoiser in your render settings. That should take care of it. Also consider moving the light up into a can light or fixture so that there is actually as source for the light to come from.
Have you got the volumetric environment on? That beam of sunlight suggests maybe so.
If so, then you’ve got yourself a nice foggy room and that is why you can see the spotlight as it is illuminating the fog.
yes the volumetric environment was on, now that i turned if off, it solved the problem.
thankyou
