def calculate_bounding_draw(view, selection)
if selection.size > 0
@bounding_box = Geom::BoundingBox.new
@bounding_box_ids = [] # Store IDs of entities within the Bounding Box
selection.each do |entity|
if entity.is_a?(Sketchup::ComponentInstance) || entity.is_a?(Sketchup::Group)
definition = entity.definition # Get ComponentDefinition / GroupDefinition
@bounding_box.add(definition.bounds) # Get original Bounding Box
@bounding_box_ids << entity.entityID
elsif entity.respond_to?(:bounds)
@bounding_box.add(entity.bounds) # Add entity bounds to the Bounding Box
end
end
@bounding_box_count = selection.size # Store the count of selected entities
else
@bounding_box = nil
@bounding_box_ids = nil
@bounding_box_count = 1 # Default count when selection is empty
end
view.invalidate # Refresh the view
end
def draw(view)
# Check if there is at least one entity in selection
if @bounding_box_count && @bounding_box_count >= 1
# Always draw Bounding Box edges
draw_bounding_box_edges(view) if @bounding_box && !@bounding_box.empty?
# Draw Bounding Box faces if needed
if @hovering_axis.nil?
draw_bounds(view) if @bounding_box && @hovered_bounding_face
end
end
end
def draw_bounding_box_edges(view)
return if @bounding_box.nil? || @bounding_box.empty?
# Expand the Bounding Box
min_pt = @bounding_box.min
max_pt = @bounding_box.max
offset = defined?(OFFSET_FACE) ? OFFSET_FACE : 1.0
expanded_min = Geom::Point3d.new(min_pt.x - offset, min_pt.y - offset, min_pt.z - offset)
expanded_max = Geom::Point3d.new(max_pt.x + offset, max_pt.y + offset, max_pt.z + offset)
# Define the corners of the bounding box
corners = [
expanded_min, # 0: bottom-front-left
Geom::Point3d.new(expanded_max.x, expanded_min.y, expanded_min.z), # 1: bottom-front-right
Geom::Point3d.new(expanded_max.x, expanded_max.y, expanded_min.z), # 2: bottom-back-right
Geom::Point3d.new(expanded_min.x, expanded_max.y, expanded_min.z), # 3: bottom-back-left
Geom::Point3d.new(expanded_min.x, expanded_min.y, expanded_max.z), # 4: top-front-left
Geom::Point3d.new(expanded_max.x, expanded_min.y, expanded_max.z), # 5: top-front-right
expanded_max, # 6: top-back-right
Geom::Point3d.new(expanded_min.x, expanded_max.y, expanded_max.z) # 7: top-back-left
# Define the edges of the bounding box
edges = {
bottom_front: [corners[0], corners[1]],
bottom_right: [corners[1], corners[2]],
bottom_back: [corners[2], corners[3]],
bottom_left: [corners[3], corners[0]],
top_front: [corners[4], corners[5]],
top_right: [corners[5], corners[6]],
top_back: [corners[6], corners[7]],
top_left: [corners[7], corners[4]],
vertical_front_left: [corners[0], corners[4]],
vertical_front_right: [corners[1], corners[5]],
vertical_back_right: [corners[2], corners[6]],
vertical_back_left: [corners[3], corners[7]]
# Draw all edges with normal lines
view.line_width = 1
view.line_stipple = ""
view.drawing_color = @color_back
edges.each_value { |start_point, end_point| view.draw(GL_LINES, start_point, end_point) }
end
Check the Ruby API docs for the bounds method. It says that for a ComponentDefinition the bounds are returned in the definition coordinates. You need to use the Group or ComponentInstance Transformation to convert them to model coordinates.
