Hi!
This is a late reply to “How to share file object from sketchup to javascript?”. Here’s how to load the content of a file from JavaScript code, running embedded in SketchUp (2017-2020), in an HtmlDialog. We can “simply” make an XMLHttpRequest object and point it to the local full path of the file. I expected the JavaScript code to deny such a request, but it doesn’t. I guess it’s either because it’s running embedded, or because I’m using htmldialog.set_file, which gives the dialog box a URL that is from a local file as well (I didn’t try with htmldialog.set_html or set_url).
The html contains:
<script type="text/javascript">
function send_file(absolute_file_path) {
var req = new XMLHttpRequest();
req.onload = function () {
var blob = req.response; // or req.responseText if you want plain text
if (blob == null) {
// oops, file couldn't be read
else {
// blob contains the file content.
// example usage: send it out with POST
var formdata = new FormData();
formdata.set("description", "...");
formdata.set("file", blob);
var upreq = new XMLHttpRequest();
upreq.onload = function () {
// should check for success or failure
upreq.open("POST", "https://example.com/upload");
upreq.send(formdata);
req.responseType = "blob"; // could be "text" if you expect a text file
req.open("GET", absolute_file_path);
req.send(null);
</script>
This will be useful for my use case because I want to send the file’s content as part of a WebSocket connection, which is not supported by Ruby. Also, I’m trusting the browser’s support for “https” to stay very up-to-date, unlike the one included with an old version of Ruby linked with an old version of OpenSSL.
Hope it is useful to someone else.
