Hi.,
I would like to print all the opened layouts to pdf.
is there is any solution?
Hi.,
Do you mean export to pdf?
If so, go to file export, after writing the name of the exported file, selecting the type of file and clicking on export a window should appear, there select all the pages, it usually is by default selected.
The title of your post says “multiple layout files”.
So, do you mean that if you have multiple Layout files open – that you want to print the contents of all of those files to pdf all at once ?
If yes then the answer is no.
Thanks @PaulMcAlenan @francisquitof .
