can someone model this entry doorway for me?
Here is a simple model … that makes heavy use of the projected image facility in SketchUp.
240924E_Door.skp (515.5 KB)
It has enough detail that it renders reasonably well with Enscape. Thus it will probably suffice if all you want to do is to stick it on the front of a building. But if you want to zoom in on the details of the stone around the door … then this model probably won’t pass muster.
Also, it would have been helpful if you had at least given the size of the door … or the RO (Rough Opening) dimensions of the door. This door in this model is a standard 80" high and non-standard 66" wide.
Also, the glass in the door and in the window above the door have been “painted” with the “projected image” … because this makes it easy to compare the model with the original image. But you may not want to see the reflected images from the original photo in your model … so all the glass is a separate “Tag” … which make it easy to use any of the usual SketchUp glass “Materials.”
your username fits your profile. def a ‘god’.
Awesome btw.
thank you so much!!! the curves in the detail is what was throwing me off
