How to make dynamic Component children inherit the onClick message
No kidding, … in the other thread I had said:
The pin and the frame leaf which would not rotate, so they’d be wrapped into a component attached to the frame.
Basically you are not listening.
You do NOT tell child sub-components that the parent was clicked.
The parent WHEN CLICKED, tells the child components TO ANIMATE.
I showed above how to do this in the parent.
Since a picture is worth a thousand words, this is a graphic representation of the component hierarchy as it should be.
The “DOOR_ASSEMBLY” sub-component rotates. The “FRAME_ASSEMBLY” sub-component stays stationary.
