def get_all_visible_entities()
begin
@visited = {}
@visible_entities = {}
all_entities = Sketchup.active_model.entities
def get_visible_entities(all_entities)
all_entities.each do |entity|
if entity.is_a?(Sketchup::Group) || entity.is_a?(Sketchup::ComponentInstance)
next if @visited[entity.definition]
@visited[entity.definition] = true
entities_inside = entity.definition.entities
get_visible_entities(entities_inside)
elsif entity.visible? && entity.layer.visible?
@visible_entities[entity] = true
end
end
end
return @visible_entities.keys
rescue => e
puts e.inspect
puts e.backtrace
end
end
In many cases, I call my function and it can’t get any entities although the entities is visible. That is because entity.layer.visible? return False while that entity is displaying. This confuses me, so how can I check the visibility of entity?
entity.layer.visible? is a entity property. If the rendering options for the model (or the current scene) is set to show hidden entities then you will see them with a hatch pattern and dashed edges.
I would need to double check, but with the addition of layer/tag folders, I think I created a hash with layer objects as the key, and ‘walked up’ the folder structure to determine if a layer was visible, and the ‘actual’ layer visibility was the value in the hash. I think I walked ‘up’ because a folder may not contain any layers, not sure.
