Do polygons have an uuid? I need the uuid to follow the transformation of the polygon trough my apps.
How can I get it, I went trough the Ruby API but I found nothing.
Does anyone knows how to get the uuid?
Thanks.
Thanks.
How are you getting the reference to this Polygon ?
It’s a collection of edges - found in a number of ways - e.g. by a pick or a selection.
So, c=edges[0].curve gives you the ArcCurve it uses.
Then c.is_polygon? confirms if c is one.
c.methods.sort lists all methods available to you - like entityID. id, object_id and the newer persistent_id ?
You could also add your own attribute dictionary item like:
c.set_attribute(“Frunza”, “polyID”, Time.now.to_f)
e.g. 1501063535.6027951
Then later on use:
polyID=c.get_attribute(“Frunza”, “PolyID”, nil)
If the curve has a polyID set you have it.
So assuming you collect all polygons you want to test in an array named polys
Use:
polyID=1501063535.6027951
polya=polys.find_all{|e| e.get_attribute(“Frunza”, “PolyID”, nil)==polyID}
You are likely to find just one in the matching aray, so:
poly=polya[0]
It depends how you are getting and using this…
Thanks @TIG,
I think I will go with entityID considering that it’s an unique ID, I don’t want to make a custom attribute.
I want to extract all the polygons as lists of vertexes and export them as json file among with the polygon uuid.
I’m curious: what are you going to do with the export? The uuids are meaningless outside SketchUp.
I pass that file trough some services, each service does some transformation to those polygons (changing their size, pruning some vertexes, maybe discard them) and I want to know each polygon’s history. Currently I a have custom implementation for the polygon uuid but I wanted to know if SketchUp provides something similar so I can use that.
