How do I export vrscene with camera details included from skp file?
I have been trying to export vrscene from skp files. While the export successfully export geometry, materials and lights, it does not export the camera details in the vrscene file. By camera details I mean the scenes defined by artists in the ‘page’ tab. The camera details can be accessed with page.camera and all the parameters such as page_name, fov, focal_length, up, target and eye are that of the artist defined poses. I see these details does not get exported as camera.
Upon inspecting vrscene I did not find any Camera with the name that was in the page tab. There was a PhysicalCamera but the parameters from this camera does not match to that of the camera defined in the page tab. Also the value for ‘scene_name’ is empty when I assume it should be the name from the page tab too. I have tried exporting manually through the UI and also the Ruby API. Is vrscene export in Vray For Sketchup limited to Geometry, Materials, lights and so on but does not export the camera or is there something I am missing ?
Are you using an extension to do this? (I do not see a .vrscene filetype listed in SketchUp’s export dialog.)
yes, I am using vray for sketchup to export vrscene.
Well then this likely needs to be asked over at the Chaos forums.
