Hello everyone,
I would like to highlight the selection of a face, with the mouse click on the face,
while I use “Class: Sketchup::Tool”, you can give me some advice, thank you.
Joseph.
Hello everyone,
Joseph.
You could use the .selection method to clear and add the face to the current_selection.
OR entirely within your own tool you could use the various draw method to add a temporary highlighted edge and/or a face.
Class: Sketchup::View — SketchUp Ruby API Documentation
etc…
Thanks for the answer, I tried to look at the code, but I could not understand much, you can further help more specific… thank you very much.
Joseph.
# Inside your tool class ...
def onLButtonUp(flags, x, y, view)
model = view.model
ph = view.pick_helper
ph.do_pick(x, y)
face = ph.picked_face
model.selection.add(face) unless face.nil?
end
Just a quick snippet.
class Testtool
def initialize
@face = nil
@tr = IDENTITY
end
def get_trans(ph, obj)
ph.count.times{|i|
if ph.leaf_at(i) == obj
return ph.transformation_at(i)
end
IDENTITY
end
def onMouseMove(flags, x, y, view)
ph_fe = view.pick_helper
ph_fe.do_pick(x, y, 0)
face = ph_fe.picked_face
@face = face ? face : nil
@tr = get_trans( ph_fe, face ) if face
view.invalidate
end
if @face
@c_face = @face
@c_tr = @tr
puts "#{@c_face} outer loop is highlighted."
end
view.invalidate
end
def draw(view)
if @face
loop = @face.outer_loop.vertices.map{|v|
v.position.transform( @tr )
view.drawing_color = [0,0,256, 64]
view.draw(GL_POLYGON, loop)
end
if @c_face
c_loop = @c_face.outer_loop.vertices.map{|v|
v.position.transform( @c_tr )
view.line_width = 3
view.drawing_color ="blue"
view.draw(GL_LINE_LOOP, c_loop)
end
end
end
Sketchup.active_model.select_tool(Testtool.new)
Dan, Can you please explain what is a drawback if I just use unless face instead?
Many thanks to all the participants, to the discussion, for their help…
Joseph.
None. No drawback. (In fact, likely faster as method calls take time.)
Just me being “picky”. (pun intended)
The docs actually do not say what is returned when the pickhelper cannot pick a face. (I assumed it would be nil.)
Thanks Dan, You reassured me.
In this case yes, it says : “Returns nil if there were no faces picked.”
However it is not in the right place (in Returns field), but above the example ![]()
I stand corrected. ![]()
6 posts were split to a new topic: Transforming picked face
