In this discussion, you’ll find two versions of tutorial graphs along with valuable insights in discussions below that led to their completion. These tutorials focus on the alignment and visibility toggling of multiple objects using parameter menu toggles.
My Graph: Multiple Individually Customizable Parts Aligned with Toggleable Visibility
In my graph, the ultimate goal was to create independent parts, each with its unique size and parameters, while allowing for customization and the ability to align with other parts. Furthermore, I wanted to toggle the visibility of each part independently. Due to these requirements, I had to treat each part as an individual entity, making them fully customizable and alignable with other components. Based on these requirements of mine, you will find duplicated nodes, where each horizontal line of nodes going left to right on screen would be considered a part, there are three total main lines of nodes, therefore three parts with unique customizing options or flexibility for each. One of the key aspects to this graph is the use of the null node. Without the null node, as Sim mentions in his below comments, the switch would not work as there would not be enough input for the switch to work, that’s where the null (dummy node) comes in. It tricks the switch in thinking it has enough input and the graph continues forward and then works well.
Link to My Graph
Sim Joubert’s Graph: Multiple Aligning Parts with Visibility Toggles, Each with a Single Option (Not Independently Customizable in Size, etc.)
I owe thanks to Sim for his assistance in this forum post. Initially, I posted a graph that didn’t quite serve the purpose outlined in the post’s title. Fortunately, through a productive discussion as seen below, Sim provided valuable examples and guidance on how to improve my initial graph. Sim’s experience with Creator was evident, and emphasized the importance of keeping graphs clean and organized.
Sim also presented an alternative approach in his example graph, utilizing a single sphere and a box to create multiple hiding parts with minimal duplication of nodes. While Sim’s approach worked well for some, it wasn’t exactly what I was aiming for. So, it’s essential to understand that there are two versions presented here and both useful in their own ways.
Link to Sim Joubert’s Graph:
Thank you for the help on this one @simjoubert, I learned a lot from the help you provided. Now I might suggest since seeing your final graph, that you organize yours!
