rtches
September 23, 2024, 1:41pm
1
I had this small script that, once it checked the file was writable, would get the file path to replace it with one that had a .csv extension.
myarray = Sketchup.active_model.path.split('.')
status = myarray.delete_at(-1)
path = myarray[0]+tipo.to_s+'.csv'
I’ve encountered issues when the username contains a dot, so I would like to know if this would be the best option or if there is a simpler one.
model_path = Sketchup.active_model.path
directory = File.dirname(model_path)
filename_without_ext = File.basename(model_path, ".*")
new_extension = ".csv"
new_file_path = File.join(directory, "#{filename_without_ext}#{new_extension}")
There is a standard library extension for this.
require 'pathname'
puts pn = Pathname.new(Sketchup.active_model.path).sub_ext('.csv')
Documentation can be found here.
https://ruby-doc.org/stdlib-2.7.2/libdoc/pathname/rdoc/index.html
https://docs.ruby-lang.org/en/3.2/Pathname.html
With just core Ruby and the API:
model = Sketchup.active_model
filename = model.title
unless filename.empty? # empty string if unsaved
dir = File.dirname(model.path).gsub(/\\\\|\\/,'/')
csv = File.join(dir, "#{filename}.csv")
end
rtches
September 23, 2024, 8:03pm
4
Thanks @sWilliams and @DanRathbun . Both works perfectly.
It seems shorter to use the library.
You want 1 statement? Okay …
Sketchup.active_model.path.sub('.skp','.csv').gsub(/\\\\|\\/,'/')
… but it does not verify that the model has previously been saved. The result of this statement will be an empty string if the model has never been saved.
rtches
September 24, 2024, 3:29am
6
I test previously if the file has been saved and if it’s writable. I had problems in the past with read only files
dezmo
September 24, 2024, 5:26am
7
Other method…
def csv_path( model = Sketchup.active_model )
m_path = model.path
if m_path == ""
UI.messagebox("Model must be saved before ... ")
nil
else
m_path.slice!(-4..-1)
m_path<<".csv"
end
end
