The first thing you need to do different is always check is the definition list already has the component loaded before loading from disk.
def get_comp(name, filename, dirpath = "Components")
mod = Sketchup.active_model
def_list = mod.definitions
cdef = def_list[name]
if !cdef
path = Sketchup.find_support_file(filename, dirpath)
cdef = def_list.load(path)
end
return cdef
rescue RuntimError # Component file is corrupt
return nil
end
Then you’ll need a method to handle a loop.
This example will copy an existing group or component instance …
def copy_array(instance, copies, spacing, axis)
base_transform = instance.transformation
model = instance.model
ents = model.active_entities
type = instance.is_a?(Sketchup::Group) ? 'Groups' : 'Instances'
added = []
model.start_operation("Copy #{copies} #{type}",true)
for i in 1..copies do
translation = (spacing * i).to_l
translate = case axis
when X_AXIS
[translation, 0, 0]
when Y_AXIS
[0, translation, 0]
when Z_AXIS
[0, 0, translation]
else
vector = Geom::Vector3d.new(axis)
vector.length= translation
vector
end
transform = base_transform * Geom::Transformation.translation(translate)
inst = ents.add_instance(instance.definition, transform)
inst.name = instance.name << " #{i}" unless instance.name.empty?
added << inst
end
model.commit_operation
return added # the array of newly added instance copies
end
So, we can modify the above method for an array of new component instances …
def comp_array(definition, initial_transform, copies, spacing, axis)
model = definition.model
added = []
model.start_operation("Component Array (#{copies})",true)
inst = ents.add_instance(definition, initial_transform)
inst.name = definition.name << " 1"
added << inst
for i in 2..copies do
when X_AXIS
[translation, 0, 0]
when Y_AXIS
[0, translation, 0]
when Z_AXIS
[0, 0, translation]
else
vector
end
transform = initial_transform * Geom::Transformation.translation(translate)
inst.name = definition.name << " #{i}"
added << inst
end
return added # the array of newly added instances
end
Where:
initial_transform can be a transformation, point, vector or array
axis can be: a vector, an array, or one of the global preset constants (X_AXIS, Y_AXIS, Z_AXIS)
copies is an Integer
spacing should be a Length object
