skapp
1
I have been looking into PickHelper to see if I can get a components position in the model.
“The PickHelper class is used to pick entities that reside under the current cursor location”
Is there a way to pick/get the x, y, z position of a component in the model?
TIG
2
Assume you have somehow got a reference to a component-instance, named ‘compo
’, then
point = compo.transformation.origin
gives you a ‘point
’ that determines its insertion point.
If you want separate X/Y/Z values, then
point.x
etc gives you those…
skapp
3
Thank you. I will try that out.
skapp
4
That worked great! Appreciate the help!!
