I have the following FIGURE 1
When I use the follow me tool, I get an empty space: see red arrow in FIGURE 2
why?
Problem 2
to eliminate the polygons, I found a tutorial which says that when you design the follow me circle to define “96s” to get a good circle. The problem is that then the follow me shape if completely different than expected!
As John says, it’s a size issue. The more faces you add on an object of a given size, the smaller the faces are. When the size of a face gets down to about 1mm (.04") in the smallest dimension, it disappears. Scale your profile up by 100x, then try it. Afterwards, you can scale it back down to full size.
