Hi all,
Brand new to Sketchup, mostly a Vectorworks user. I’m using the Sketchup For Schools web based platform. I was following along with the Wizard of Oz Set Design Tutorial and I ran into two issues. First is that when I right click on a texture, it should have the Fixed Pins option highlighted but it doesn’t. I know that I can hold down Shift to toggle them off-- hence why in the picture he pins appear gray since I had to hold down shift to take the screenshot. Is there a setting I need to adjust in order to have it appear active when I right click so that I can turn off Fixed Pins without it just being a toggle?
Second issue is I’m not seeing the Layers option in the panels section on the right. I assumed I was using the same version as what’s in the video since it was just published last week. Instead it has a Tag spanel. It seems like Tags is the same as Layers (it performed the same functions described in the tutorial video), but is there any difference I should know about?
Thanks!
