Finding a bug in SUFaceGetUVTileAt
I got different UVTile with ruby and C.
There is only one face in the model.
ruby code
Sketchup.active_model.active_entities.grep(Sketchup::Face).each do |face|
  puts "===========reference #{ORIGIN}============="
  reference = ORIGIN
  mapping = face.uv_tile_at(reference, true)
  mapping.each_slice(2) { |position, uv|
    puts "World: #{position.inspect} - UV: #{uv.inspect}"
end
ruby output
===========reference (0 mm, 0 mm, 0 mm)=============
World: Point3d(0, 0, 0) - UV: Point3d(0, 0, 0)
World: Point3d(196.85, 0, 0) - UV: Point3d(1, 0, 0)
World: Point3d(196.85, 196.85, 0) - UV: Point3d(1, 1, 0)
World: Point3d(0, 196.85, 0) - UV: Point3d(0, 1, 0)
C code
#include<SketchUpAPI\sketchup.h>
#include<stdio.h>
#include<vector>
#include<assert.h>
#include<algorithm>
#define SU(api_function_call) {\
  SUResult su_api_result = api_function_call;\
  assert(SU_ERROR_NONE == su_api_result);\
void debug(const char *fmt, ...) {
	va_list args;
	va_start(args, fmt);
	vprintf(fmt, args);
	va_end(args, fmt);
int main() {
	SUInitialize();
	SUModelRef src_model = SU_INVALID;
	SUModelLoadStatus loadStatus;
	// get the model from test_src.skp  =>  src_model
	SU(SUModelCreateFromFileWithStatus(&src_model, "F:\\Desktop\\test.skp", &loadStatus));
	SUEntitiesRef src_entities = SU_INVALID;
	// get the entities of the src_model
	SU(SUModelGetEntities(src_model, &src_entities));
	// get number of faces
	size_t face_num = 0;
	SU(SUEntitiesGetNumFaces(src_entities, &face_num));
	// get faces
	std::vector<SUFaceRef> faces(face_num);
	SU(SUEntitiesGetFaces(src_entities, face_num,&(faces[0]), &face_num));
	// There is only one face in the model
	SUMaterialPositionInput mat_pos_input_front;
	mat_pos_input_front.num_uv_coords = 4;
	SUPoint3D pt;
	pt.x = pt.y = pt.z = 0;
	SU(SUFaceGetUVTileAt(faces[0], &pt, true, &(mat_pos_input_front.points[0]), &(mat_pos_input_front.uv_coords[0])));
	debug("===========reference (0 mm, 0 mm, 0 mm)=============\n");
	for (int i = 0; i < mat_pos_input_front.num_uv_coords; i++) {
		debug("World: Point3d(%lf, %lf, %lf)", mat_pos_input_front.points[i].x, mat_pos_input_front.points[i].y, mat_pos_input_front.points[i].z);
		debug(" - UV: Point3d(%lf, %lf, 0)\n", mat_pos_input_front.uv_coords[i].x, mat_pos_input_front.uv_coords[i].y);
	SU(SUModelRelease(&src_model));
	SUTerminate();
	return 0;
C output
===========reference(0 mm, 0 mm, 0 mm)=============
World: Point3d(0.000000, 0.000000, 0.000000) - UV : Point3d(0.000000, 0.000000, 0)
World : Point3d(0.000000, 0.000000, 0.000000) - UV : Point3d(0.000000, 0.000000, 0)
test.skp (522.9 KB)
Sorry,I mentioned this bug before.the bug
Have you updated your SDK to the latest (v 10.1) and retested ?
Yes, I use the SDK(2020.0.356). It’s ok.
I should say " Sorry,I mentioned this bug before. And the bug has been fixed "
